sixsevans
Aug 11, 2019Tutor
CM1200. Can ports 2,3,4 be used other than for Port Aggregation?
The description on Amazon says:
- VERSATILE CONNECTIONS: 4 Gigabit Ethernet ports give you fast wired connections to your computer, separate Wi-Fi router, printer, game box, and other devices.
But the user manual only discusses LAN 2 port in the sections about Port Aggregation.
Also the CM1200 documentation ONLY mentions port LAN 1 & LAN 2, i.e., LAN 3 & LAN 4 are never mentioned in the product documenation, which seems weir for a 4 port device.
Port 1 & 2 can be used for port aggregation. The other ports can't be used unless your ISP provisions you with multiple IP addresses (one for each port)
1 Reply
