Pibe38
May 03, 2020Aspirant
[CM1200] Constant Internet Drop on Spectrum
Hello, A few days ago I decided to purchase my own modem. I originally purchased the Arris SB8200. 24 hours after activation I started having my connection drop every so often; it would come back...
Lito628
Feb 08, 2021Tutor
Having the same issues as others. We need a solution here. I’ve tried ALL the standard procedure and had my ISP check everything. Cables are good, router is good, did reboot, update and factory reset. Nothing is working to fix the issue. Why is this not being solved by now? I need help??
- FURRYe38Feb 08, 2021Guru - Experienced User
