Hey, thanks for the quick response. Ill try that and see. Please find the cable connection below.
| Startup Procedure |
| Procedure | Status | Comment | | Acquire Downstream Channel | 429000000 Hz | Locked | | Connectivity State | OK | Operational | | Boot State | OK | Operational | | Security | Enabled | BPI+ | | IP Provisioning Mode | Honor MDD | honorMdd(4) |
| Downstream Bonded Channels |
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Correctables | Uncorrectables | | 1 | Locked | QAM256 | 45 | 429000000 Hz | -1.4 dBmV | 44.1 dB | 47 | 178 | | 2 | Locked | QAM256 | 1 | 675000000 Hz | -0.6 dBmV | 43.1 dB | 25 | 44 | | 3 | Locked | QAM256 | 2 | 681000000 Hz | -0.9 dBmV | 44.1 dB | 14 | 54 | | 4 | Locked | QAM256 | 3 | 687000000 Hz | -1.2 dBmV | 43.9 dB | 26 | 46 | | 5 | Locked | QAM256 | 4 | 693000000 Hz | -1.9 dBmV | 43.5 dB | 25 | 45 | | 6 | Locked | QAM256 | 5 | 699000000 Hz | -2.4 dBmV | 43.1 dB | 19 | 55 | | 7 | Locked | QAM256 | 6 | 705000000 Hz | -2.7 dBmV | 42.9 dB | 55 | 27 | | 8 | Locked | QAM256 | 7 | 711000000 Hz | -2.7 dBmV | 42.9 dB | 28 | 29 | | 9 | Locked | QAM256 | 8 | 717000000 Hz | -2.3 dBmV | 43.1 dB | 35 | 23 | | 10 | Locked | QAM256 | 9 | 723000000 Hz | -1.9 dBmV | 43.4 dB | 30 | 23 | | 11 | Locked | QAM256 | 10 | 729000000 Hz | -1.6 dBmV | 43.5 dB | 34 | 26 | | 12 | Locked | QAM256 | 11 | 735000000 Hz | -1.4 dBmV | 43.6 dB | 26 | 42 | | 13 | Locked | QAM256 | 12 | 741000000 Hz | -1.4 dBmV | 43.5 dB | 18 | 51 | | 14 | Locked | QAM256 | 13 | 747000000 Hz | -1.5 dBmV | 43.4 dB | 26 | 48 | | 15 | Locked | QAM256 | 14 | 753000000 Hz | -1.6 dBmV | 43.4 dB | 21 | 60 | | 16 | Locked | QAM256 | 15 | 759000000 Hz | -1.6 dBmV | 43.4 dB | 15 | 56 | | 17 | Locked | QAM256 | 16 | 765000000 Hz | -1.8 dBmV | 43.3 dB | 160 | 26 | | 18 | Locked | QAM256 | 33 | 357000000 Hz | -0.3 dBmV | 44.6 dB | 34 | 75 | | 19 | Locked | QAM256 | 34 | 363000000 Hz | -0.4 dBmV | 44.6 dB | 24 | 85 | | 20 | Locked | QAM256 | 35 | 369000000 Hz | -0.6 dBmV | 44.5 dB | 26 | 107 | | 21 | Locked | QAM256 | 36 | 375000000 Hz | -0.6 dBmV | 44.5 dB | 31 | 152 | | 22 | Locked | QAM256 | 37 | 381000000 Hz | -0.6 dBmV | 44.5 dB | 49 | 165 | | 23 | Locked | QAM256 | 38 | 387000000 Hz | -0.6 dBmV | 44.5 dB | 35 | 203 | | 24 | Locked | QAM256 | 39 | 393000000 Hz | -0.6 dBmV | 44.5 dB | 40 | 218 | | 25 | Locked | QAM256 | 40 | 399000000 Hz | -0.6 dBmV | 44.5 dB | 33 | 216 | | 26 | Locked | QAM256 | 41 | 405000000 Hz | -0.6 dBmV | 44.5 dB | 44 | 200 | | 27 | Locked | QAM256 | 42 | 411000000 Hz | -0.7 dBmV | 44 dB | 67 | 212 | | 28 | Locked | QAM256 | 43 | 417000000 Hz | -1 dBmV | 44.4 dB | 63 | 206 | | 29 | Locked | QAM256 | 44 | 423000000 Hz | -1.2 dBmV | 44.2 dB | 71 | 213 | | 30 | Locked | QAM256 | 46 | 435000000 Hz | -1.5 dBmV | 44 dB | 77 | 183 | | 31 | Locked | QAM256 | 47 | 441000000 Hz | -1.8 dBmV | 44 dB | 17 | 102 | | 32 | Locked | QAM256 | 48 | 447000000 Hz | -1.8 dBmV | 44 dB | 153 | 420 |
| Upstream Bonded Channels |
| Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power | | 1 | Locked | ATDMA | 1 | 5120 Ksym/sec | 17400000 Hz | 39 dBmV | | 2 | Locked | ATDMA | 2 | 5120 Ksym/sec | 23900000 Hz | 39.5 dBmV | | 3 | Locked | ATDMA | 3 | 5120 Ksym/sec | 30300000 Hz | 39.5 dBmV | | 4 | Locked | ATDMA | 4 | 5120 Ksym/sec | 36700000 Hz | 39.5 dBmV | | 5 | Locked | ATDMA | 5 | 5120 Ksym/sec | 60000000 Hz | 39.5 dBmV | | 6 | Locked | ATDMA | 6 | 5120 Ksym/sec | 67000000 Hz | 40 dBmV | | 7 | Locked | ATDMA | 7 | 5120 Ksym/sec | 74000000 Hz | 40.8 dBmV | | 8 | Locked | ATDMA | 8 | 5120 Ksym/sec | 81000000 Hz | 40.8 dBmV |
| Downstream OFDM Channels |
| Channel | Lock Status | Modulation / Profile ID | Channel ID | Frequency | Power | SNR / MER | Active Subcarrier Number Range | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords | | 1 | Locked | 0 ,1 ,2 ,3 | 159 | 300000000 Hz | 0.4 dBmV | 44.9 dB | 2216 ~ 5975 | 1909698306 | 234000733 | 877 | | 2 | Not Locked | 0 | 0 | 0 Hz | 0 dBmV | 0.0 dB | 0 ~ 4095 | 0 | 0 | 0 |
| Upstream OFDMA Channels |
| Channel | Lock Status | Modulation / Profile ID | Channel ID | Frequency | Power | | 1 | Not Locked | 0 | 0 | 0 Hz | 0 dBmV | | 2 | Not Locked | 0 | 0 | 0 Hz | 0 dBmV |
