jwade99's avatar
jwade99
CM1200 frequent drops in upload and download
brand new modem, ISP service connected to RAX80 router.   SImple setup, no linke agg (just bouth the ability for the future).  ISP service (400gbs up, 40gps down optimum) is good 80% of the time, but randomly drops during the day to bad levels (almost zero or zero up and down).   Have had multiple visits from techs and in each case they blamed on outside lines and made adjustments.   ISP is suggesting that cm1200 is bad and is recommending replacement with their modem.   Modem firmware is 1.01.02, online netgear support shows 1.02.xx available but I can't get the ISP to push the firmware to see if it helps.     Full logs in attachment.
Highlights noted some correctables in the download.
Channel
Lock Status
Modulation
Channel ID
Frequency
Power
SNR
Correctables
Uncorrectables
1
Locked
QAM256
6
609000000 Hz
6.7 dBmV
39.5 dB
0
0
2
Locked
QAM256
1
567000000 Hz
5.2 dBmV
39.3 dB
85
79
3
Locked
QAM256
2
573000000 Hz
6 dBmV
39.6 dB
10
46
Upload
Upstream Bonded Channels
Channel
Lock Status
US Channel Type
Channel ID
Symbol Rate
Frequency
Power
1
Locked
ATDMA
64
5120 Ksym/sec
35000000 Hz
45.5 dBmV
2
Locked
ATDMA
65
5120 Ksym/sec
28400000 Hz
45.5 dBmV
3
Locked
ATDMA
66
5120 Ksym/sec
22000000 Hz
45.3 dBmV
4
Locked
ATDMA
67
5120 Ksym/sec
14000000 Hz
45 dBmV
5
Not Locked
Unknown
0
0 Ksym/sec
0 Hz
0.0 dBmV
6
Not Locked
Unknown
0
0 Ksym/sec
0 Hz
0.0 dBmV
7
Not Locked
Unknown
0
0 Ksym/sec
0 Hz
0.0 dBmV
8
Not Locked
Unknown
0
0 Ksym/sec
0 Hz
0.0 dBmV
Upstream OFDMA Channels
Channel
Lock Status
Modulation / Profile ID
Channel ID
Frequency
Power
1
Not Locked
0
0
0 Hz
0 dBmV
2
Not Locked
0
0
0 Hz
0 dBmV
Logs
Time
Priority
Description
Wed Jun 03 12:50:31 2020
Warning (5)
DHCP WARNING - Non-critical field invalid in response ;CM-MAC=28:80:88:b0:b6:f0;CMTS-MAC=00:01:5c:7d:16:64;CM-QOS=1.1;CM-VER=3.1;
Time Not Established
Notice (6)
Honoring MDD; IP provisioning mode = IPv4
Critical (3)
SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=28:80:88:b0:b6:f0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
Wed Jun 03 12:49:48 2020
Critical (3)
Resetting the cable modem due to docsDevResetNow
Tue Jun 02 19:15:23 2020
Critical (3)
Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=28:80:88:b0:b6:f0;CMTS-MAC=00:01:5c:7d:16:64;CM-QOS=1.1;CM-VER=3.1;
Critical (3)
Tue Jun 02 09:39:26 2020
Critical (3)
Mon Jun 01 18:18:52 2020
Critical (3)
Mon Jun 01 05:19:44 2020
Critical (3)
Critical (3)
Thu May 28 16:26:59 2020
Critical (3)
  • FURRYe38's avatar
    Have the ISP check the signal and line quality UP to the modem.
    Be sure there are no coax cable line splitters in the between the modem and ISP service box.
    Be sure your using good quality RG6 coax cable up to the modem.
    Try a different modem as well. See if the problem still happens or not.
    • jwade99's avatar
      jwade99
      I had another tech come out and they did verify that there was noise in the line.   Regarding firmware upgrades, I purchased the modem form a retailier so is the ISP still responsible for firmware upgrades?
      • FURRYe38's avatar
        Some ISPs may not do FW updates on user owned modems. Something to ask the ISP about.
