cpdc1030's avatar
cpdc1030
CM1200 intermittent packet loss / Xfinity
Hi there,
My setup {Xfinity Gigabit Service} -> CM1200 -> Orbi RBR50 / RBS50
I upgraded the service to Gigabit in September, my old modem (which I still have, is a CM500) is DOCSIS 3.0 and not able to make full use of the faster service (3.1), so I bought the CM1200 based on my good experience with other Netgear products. When all is working, it is great, and I get 920 Mbps down and ~40Mbps up. However the connectivity is unreliable and I can't continue to use the modem.
I've been using it occasionally, but always end up going back to the CM500 due to instability when connecting with the CM1200. After a random amount of time, usually a few hours, the connectivity becomes unstable - I've observed ~20-30% packet loss on PingPlotter. A reboot of the CM1200 resolves the issue, but I can't keep rebooting it multiple times per day (I already have a nightly reboot timer switch set up...). The CM500 never has these problems and the connectivity is rock solid.
During one recent incident, I saw this in the modem logs, MAC addresses removed:
Started Unicast Maintenance Ranging - No Response received - Wed Dec 30 13:16:57 2020 Critical (3) T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-
MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
Around the same time, I saw these ACK Scan entries in the RBR50 logs, not sure if they are somehow related:
[DoS Attack: ACK Scan] from source: 157.240.22.54, port 443, Wednesday, December 30, 2020 13:13:19
[DoS Attack: ACK Scan] from source: 104.244.42.2, port 443, Wednesday, December 30, 2020 13:12:11
[DoS Attack: ACK Scan] from source: 104.244.42.65, port 443, Wednesday, December 30, 2020 13:12:02
I've opened a case with Xfinity and they were not able to find any problems after running diagnostics. They are pointing the finger at the modem, which is still under hardware warranty but has no other support (seems a bit contradictory).
Any help or advice is most appreciated!
Thanks.
