julian12it
Aug 01, 2019Follower
CM1200 Internet Speed Problem
Hello fourm, I recently purchased a Nighthawk CM1200 Modem and a Nighthawk R6700 Router. The router was the first to arrive in the mail and I decided to set it up with my previous router. All was goo...
CPLMayo
Aug 13, 2019Guide
When you use more than one Ethernet port on the Cable Modem you are using LACP Link Aggregation which has been identified as an issue on the CM1200. You may want to post in the previous thread below with what you are seeing and which ISP you are using.
