Dibbler
Feb 02, 2024Follower
CM1200 it shouldn’t be this hard!
Can someone please help… I registered the CM1200 Cable Modem with Xfinity, all fine, the Netgear shows up, try the password as password, can’t login, I reset the device as instructed, same again. ...
Feb 02, 2024Guru - Experienced User
Problem is is that some versions of firmware will accept password when you put it in but it won't take because it doesn't meet the minimum requirements for xifnity.
After you factory reset it, next time you setup the password make sure to have:
10 characters
1 special one
1 capital letter
1 lower case letter
1 number.
Try that when you change the password
