Azriel
Aug 21, 2019Follower
Cm1200 not connected to smarthome
Purchased smart home with echo dot, SmartThings hub, Honeywell thermostat, ring doorbell, Kwikset smart door lock all connected to a Ruckus ICX 7150-C12P. My X10 is connected to the CM1200 and so is the ICX 7150-C12P. My problem is that it’s not communicating anymore. I’ve power cycled all three units and no comms. ISP has refreshed signals but same problem. Is there something I’m missing?
> [...] My X10 is connected to the CM1200 and so is the ICX 7150-C12P.
> [...]Connect WAN/Internet port of the "X10" (not a model number) router to
the "LAN 1" port of the CM1200. Connect the switch to a LAN port on the
"X10".Visit http://netgear.com/support , put in your modem model number,
and look for Documentation. Get the User Manual. Read. Look for "LAN
ports". Keep reading.- vkdeltaNETGEAR Employee Retired
Always ONLY connect 1 device behind Cable unless you have multiple IP service from your ISP (which many folks do not have).
CM1200 - > NightHawk X10 -> Ruckus switch --> all the wired devices.
Other 3 ports behind CM1200 should not be used unless you have Multiple IP service from your ISP
