mhoffman78
Jan 25, 2023Follower
CM1200 Ports
Hello,
I have a CM1200 and seems to be working just fine. However, when I plug a laptop directly into Port 1, the laptop can not access the internet. When I plug my WIFI router into Port 1, I am able to access the internet. I was trying to test my internet speed by directly plugging into the modem and bypassing the router. Does anyone know why I cannot access the internet directly through the modem and not through the router? I am using a Windows 10 Home Edition
Thanks!
1. Even though it has 4x ports, most ISP's only support 1 public ip address. meaning only 1 device connected to it.
2. to over come this. disconnect the modem from the computer/router. power it off for 10 minutes. power it back on with nothing connected and wait 2 minutes. Then connect your computer and turn it on. give it a couple minutes to fully boot. Then try it.
usually that frees up that public ip address to be re-assigned to your computer.
1 Reply
