gandestudios's avatar
gandestudios
cm1200
We have had continuous problems with the modem dropping internet.  we have troubleshoot with IPS and had techs out to check service.  it will work fine for a while and then start dropping internet CONTINUOUSLY.  we have not had the unit long and thought it was the IPS provider that was the problem..  my productivity is down and this has got to be fixed.  help is appreciated.
  • plemans's avatar
    The screen shots of the cable connections page and logs help with checking line issues.
    Also, if you have any splitters, amplifiers, attenuators in line, remove them.
    check the line for kinks, damage, corrosion, cheap/bad/loose connectors.
  • I am having the same problem.  ISP came out and checked the signal, reterminated the coax, and removed a splitter.  It seemed OK for a couple of days before service dropped again.  If I unplug the modem and plug it back in service is fine for a while.  When the connection is down the upload light is flashing.  Just got off the phone with Netgear and am trying a factory reset....
    • FURRYe38's avatar
      What firmware version is loaded on the modem?
      Who is your ISP?
      • MondoMaryland's avatar
        MondoMaryland
        Who is your ISP?
        Thanks for the reply, Furry,
        Firmware Version V2.02.05
        ISP is RCN
        I tried enabling this yesterday, but still lost connection to ISP again last night and had unplug modem to reestablish.
        Extended Upstream Transmit Power
        Enable Extended Upstream Transmit Power
        Log entries and channels are attached.
        Any insight woud be appreciated.
        C
