NaBBiX's avatar
NaBBiX
Follower
Oct 13, 2023
CM2000 Rapid flashing lights new setup
I unplugged my older CM1000 and plugged in new CM2000 as instructed with COAX cable. Rapid flashing white lights occurred immediately and has not changed. I’ve held reset for ~15 seconds Unplug coax...
  • plemans's avatar
    Oct 13, 2023
    Probably got a defective unit. All flashing lights tends to be a hardare failure.
    It's more than likely faster to exchange it wherever you bought it than go through netgears rma process.
