bheg's avatar
bheg
CM2000 stop working all of a sudden
Hello All,
I been troubleshooting my network the last 4 hours and narrow it down to the my modem (CM2000). I bought it in 2021 and looks like the one year warranty expire already, go figure...So all the light comes up but it doesn't do anything else. I know it's the modem cause if I connect ISP modem my network works fine, I put in another old modem Netgear CM1100 and it also works fine. If I plug up the CM2000 however everything just stop working with my firewall showing unable to obtain IP. Is it possible for netgear to still RMA the product? I feel like I just wasted 200 bucks that only lasted a year...
Thank You
  • plemans's avatar
    If you hardwire in a pc/laptop to it, are you able to access its gui?
    Did you try factory resetting it?
    Disconnect the coax from it and while powered on, hold reset for up to 30 seconds.
    • bheg's avatar
      bheg
      Already tried that, straight lan to desktop no connection to gui even after factory reset.
      • plemans's avatar
        With the cm2000 hooked up, is the isp able to activate and see it?
        Thats where I'd start. Get them able to activate it.
        Once they can (if they can), let it self activate. Then power it off, give it 2 minutes, and connect the router back up to it.
        then power the modem up give it 2 minutes and power the router up.
        Usually if the modem lights are all on (depending on color) and solid, its still working.
