Ace_Card
Sep 06, 2025Aspirant
CM2050V - Latest Firmware Preventing 2.5 Gbps Passthrough on Ethernet Port
Hello all, and specifically to the moderator, I'm reporting a potential firmware or hardware version defect where the native Ethernet port fails to pass through 2.5 Gbps speeds to the LAN, with f...
- Sep 16, 2025
Thank you all for your helpful input and suggestions!
I wanted to share that my issue is now resolved.
Initially, getting support from Netgear for my out-of-warranty modem was challenging, especially for what seemed like an "ISP-side firmware" issue. I couldn’t open a case via phone or chat without purchasing a support plan, which was frustrating. So, I turned to my ISP for help.
I connected with an upper tier technician who, despite initially pointing to the modem vendor (since it’s customer owned), worked with me to troubleshoot the issue. After another reset/refresh on their end, the ethernet port finally was able to deliver the 2.5 gig expected speed (1900 to 2100 Mbps).
CrimpOn
Sep 06, 2025Guru - Experienced User
It would appear that the Fluke CableIQ tester is rated for gigabit Ethernet. Might lead to a conclusion that it is not capable of measuring higher speeds.
Does this router include a Speed Test that can be run on the router itself?
Would be really helpful to have a computer with a 2.5GB Ethernet adapter that could be connected directly to the modem to run a speed test.
It is not obvious (to me) how a customer would open a support ticket on a product purchased in 2021 (four years ago).
