cmarti02
Jan 04, 2024Aspirant
CM2050V - Lights have stopped working - need to worry?
In the past 6 months, the Upload light on my CM2050V has stopped working. I assume that is due to the Firmware issue. I had the same exact issue from 2019-2022 with another Netgear modem. No fix, just both sides pointing fingers at the other to fix it. It was the reason I finally upgraded to the CM2050V, now same issue.
But, in the past month, most of the lights have stopped working on the unit. Power, Download and the Online lights have stopped working. The only lights that are working now, are the Ethernet and Phone1 lights are working. The modem does still work, but I'm concerned the modem is dying. I worked with Netgear support and went thru troubleshooting. Their opinion is, since the Power light doesn't work, it's a hardware issue.
I work from home, so this is a big issue for me. After going thru the troubleshooting session yesterday (01/03), I went to Best Buy and bought another CM2050V, just in case.
All opinions are welcome,
Curtis
What ISP are you connected with?
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-routerMight try a different power supply adapter with same volts and amps.
- cmarti02Aspirant
1. What ISP are you connected with? Xfinity
2. What Firmware version is currently loaded? V2.01.03, which I believe is the latest/right one.
3. 32 DL channels are locked, only 2 UL (1&5 channels locked), only 1 OFDM locked, 0 OFDMA channels locked.
Startup Procedure Procedure Status Comment Acquire Downstream Channel 501000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enabled BPI+ Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 12 501000000 Hz -0.4 dBmV 39.4 dB 2 0 2 Locked QAM256 1 435000000 Hz 0.4 dBmV 39.6 dB 338 637 3 Locked QAM256 2 441000000 Hz -1.0 dBmV 39.0 dB 786 1603 4 Locked QAM256 3 447000000 Hz -1.7 dBmV 38.7 dB 1086 3398 5 Locked QAM256 4 453000000 Hz -0.1 dBmV 39.2 dB 388 1016 6 Locked QAM256 5 459000000 Hz 1.1 dBmV 39.7 dB 248 791 7 Locked QAM256 6 465000000 Hz 1.6 dBmV 39.7 dB 282 695 8 Locked QAM256 7 471000000 Hz 2.1 dBmV 39.8 dB 265 622 9 Locked QAM256 8 477000000 Hz 2.2 dBmV 39.9 dB 216 642 10 Locked QAM256 9 483000000 Hz 1.8 dBmV 39.9 dB 218 582 11 Locked QAM256 10 489000000 Hz 1.1 dBmV 39.7 dB 298 756 12 Locked QAM256 11 495000000 Hz 0.3 dBmV 39.5 dB 328 972 13 Locked QAM256 13 507000000 Hz -0.7 dBmV 39.4 dB 302 811 14 Locked QAM256 14 513000000 Hz -0.8 dBmV 39.4 dB 287 1082 15 Locked QAM256 15 519000000 Hz -0.9 dBmV 39.5 dB 245 785 16 Locked QAM256 16 525000000 Hz -0.7 dBmV 39.7 dB 220 789 17 Locked QAM256 17 531000000 Hz -0.4 dBmV 39.6 dB 246 996 18 Locked QAM256 18 537000000 Hz 0.3 dBmV 40.0 dB 215 704 19 Locked QAM256 19 543000000 Hz 0.7 dBmV 40.1 dB 231 480 20 Locked QAM256 20 549000000 Hz 0.8 dBmV 40.1 dB 360 1110 21 Locked QAM256 21 555000000 Hz 0.6 dBmV 39.9 dB 195 597 22 Locked QAM256 22 561000000 Hz 0.4 dBmV 39.8 dB 303 1013 23 Locked QAM256 23 567000000 Hz 0.2 dBmV 39.8 dB 218 598 24 Locked QAM256 24 573000000 Hz -0.1 dBmV 39.6 dB 183 622 25 Locked QAM256 25 579000000 Hz -0.8 dBmV 39.4 dB 244 1169 26 Locked QAM256 26 585000000 Hz -1.5 dBmV 39.1 dB 243 637 27 Locked QAM256 27 591000000 Hz -2.1 dBmV 38.8 dB 264 624 28 Locked QAM256 28 597000000 Hz -2.4 dBmV 38.6 dB 275 709 29 Locked QAM256 29 603000000 Hz -2.4 dBmV 38.6 dB 220 604 30 Locked QAM256 30 609000000 Hz -2.8 dBmV 38.4 dB 207 699 31 Locked QAM256 31 615000000 Hz -3.1 dBmV 38.3 dB 226 718 32 Locked QAM256 32 621000000 Hz -3.3 dBmV 38.2 dB 231 675 Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 1 5120 35600000 Hz 40.3 dBmV 2 Locked ATDMA 5 2560 40400000 Hz 39.0 dBmV 3 Not Locked Unknown 0 0 0 Hz 0.0 dBmV 4 Not Locked Unknown 0 0 0 Hz 0.0 dBmV 5 Not Locked Unknown 0 0 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 0 Hz 0.0 dBmV Downstream OFDM Channels Channel Lock Status Profile ID Channel ID Frequency Power SNR / MER Active Subcarrier
Number RangeUnerrored
CodewordsCorrectable
CodewordsUncorrectable
Codewords1 Locked 0 ,1 ,2 ,3 193 702000000 Hz -3.9 dBmV 37.2 dB 1108 ~ 2987 723611120 570833372 0 2 Not Locked 0 0 0 Hz 0 dBmV 0.0 dB 0 ~ 4095 0 0 0 Upstream OFDMA Channels Channel Lock Status Modulation / Profile ID Channel ID Frequency Power 1 Not Locked 0 0 0 Hz 0 dBmV 2 Not Locked 0 0 0 Hz 0 dBmV 4. Event Status log
Time Priority Description Thu Jan 04 17:47:02 2024 (Critical (3)) No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:b4:23:b0;CMTS-MAC=00:90:f0:43:05:00;CM-QOS=1.1;CM-VER=3.1; Thu Jan 04 10:25:04 2024 (Notice (6)) CM-STATUS message sent. Event Type Code: 22; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:b4:23:b0;CMTS-MAC=00:90:f0:43:05:00;CM-QOS=1.1;CM-VER=3.1; Thu Jan 04 10:25:04 2024 (Notice (6)) CM-STATUS message sent. Event Type Code: 23; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:b4:23:b0;CMTS-MAC=00:90:f0:43:05:00;CM-QOS=1.1;CM-VER=3.1; Thu Jan 04 10:25:04 2024 (Notice (6)) CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=08:36:c9:b4:23:b0;CMTS-MAC=00:90:f0:43:05:00;CM-QOS=1.1;CM-VER=3.1; - FURRYe38Guru - Experienced User
Power is ok.
Correctables and Un-correctables should be zeros.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?If you get the 2nd CM modem, try it's power adapter on the 1st modem to see if the LED behavoirs change.
Have you powered OFF the 1st modem and disconnected it from the ISP coax line then powered it on to see if the LEDs change behavior?
Any Factory resets as well?
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
