JSchm83's avatar
JSchm83
CM2050V + Altice with voice
Does anyone know if the CM2050V will also work on Altice? I know it says xfinity and the service is similar, just wanted to check and see if anyone knew before I pull the trigger
  • FURRYe38's avatar
    Call the ISP first to ask abot this. They will know. I think the CM with voice is meant for CC mostly.
  • plemans's avatar
    As far as I know, the only isp its certified with is xfinity.
    vkdelta  would know if more ISP's are being added.
    • JSchm83's avatar
      JSchm83
      Would be great if it could be.
      ISP's have a tendency to qualify junk and ignore quality hardware
      • vkdelta's avatar
        vkdelta
        NETGEAR Employee Retired
        It wont work with altice. please do not purchase for altice.
