Mtphillips88's avatar
Jul 02, 2024
CM2050V modem drops connection/freezes
Having a problem with my CM2050V Modem.
Will drop connection randomly about once a day. Power cycling the device was working to fix the issue for a while. It will now drop connection, and then freeze, (unable to log in via a web browser/"not responding" being reported in windows diagnostic/troubleshooting tool. I have to factory reset the device to get it to function properly and be able to log in to the modem.
When it freezes, the "power light" alternates flashing with the "downstream/upstream/online lights". After it is factory reset, I am able to log in and internet connection is restored. Once restored it will function properly for a few hours then I will have to repeat the process again.
I opened a support ticket with NetGear but figured I would check here in the mean time to see if there was a fix or if I need to RMA the modem.
ISP: Xfinity. (comcast)
Hardware version 1.01
Cable Firmware version V2.01.03
OS Windows 11 (but also used with other internet connected devices; TVs, Phones, Gaming devices etc...)
Using the modem in conjunction with Nighthawk Pro Gaming WiFi 6 Gaming Router (XR1000)
Thanks for any and all advice.
    • Mtphillips88's avatar
      Mtphillips88
      Guide
      Event Log
      Clear Log Refresh Export
      TimePriorityDescription
      Tue Jul 02 16:12:02 2024(Notice (6))CM-STATUS message sent. Event Type Code: 5; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=6c:cd:d6:ce:65:e4;CMTS-MAC=00:01:5c:77:e6:51;CM-QOS=1.1;CM-VER=3.1;
      Tue Jul 02 16:11:49 2024(Notice (6))DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=6c:cd:d6:ce:65:e4;CMTS-MAC=00:01:5c:77:e6:51;CM-QOS=1.1;CM-VER=3.1;
      Tue Jul 02 16:11:44 2024(Notice (6))TLV-11 - unrecognized OID;CM-MAC=6c:cd:d6:ce:65:e4;CMTS-MAC=00:01:5c:77:e6:51;CM-QOS=1.1;CM-VER=3.1;
      Time Not Established(Notice (6))Honoring MDD; IP provisioning mode = IPv6
      Time Not Established(Critical (3))No Ranging Response received - T3 time-out;CM-MAC=6c:cd:d6:ce:65:e4;CMTS-MAC=00:01:5c:77:e6:51;CM-QOS=1.1;CM-VER=3.1;
      Time Not Established(Critical (3))SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=6c:cd:d6:ce:65:e4;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Tue Jul 02 15:39:57 2024(Notice (6))DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=6c:cd:d6:ce:65:e4;CMTS-MAC=00:01:5c:77:e6:51;CM-QOS=1.1;CM-VER=3.1;
      Tue Jul 02 15:39:52 2024(Notice (6))TLV-11 - unrecognized OID;CM-MAC=6c:cd:d6:ce:65:e4;CMTS-MAC=00:01:5c:77:e6:51;CM-QOS=1.1;CM-VER=3.1;
      Tue Jul 02 15:28:00 2024(Notice (6))CM-STATUS message sent. Event Type Code: 5; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=6c:cd:d6:ce:65:e4;CMTS-MAC=00:01:5c:77:e6:51;CM-QOS=1.1;CM-VER=3.1;
      Tue Jul 02 15:27:50 2024(Warning (5))Dynamic Range Window violation
      Tue Jul 02 15:27:50 2024(Warning (5))RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=6c:cd:d6:ce:65:e4;CMTS-MAC=00:01:5c:77:e6:51;CM-QOS=1.1;CM-VER=3.1;
      Tue Jul 02 15:27:44 2024(Critical (3))SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=6c:cd:d6:ce:65:e4;CMTS-MAC=00:01:5c:77:e6:51;CM-QOS=1.1;CM-VER=3.1;
      Tue Jul 02 15:27:44 2024(Notice (6))DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=6c:cd:d6:ce:65:e4;CMTS-MAC=00:01:5c:77:e6:51;CM-QOS=1.1;CM-VER=3.1;
      Tue Jul 02 15:27:43 2024(Notice (6))TLV-11 - unrecognized OID;CM-MAC=6c:cd:d6:ce:65:e4;CMTS-MAC=00:01:5c:77:e6:51;CM-QOS=1.1;CM-VER=3.1;
      Tue Jul 02 15:27:32 2024(Notice (6))Honoring MDD; IP provisioning mode = IPv6
      Tue Jul 02 15:27:28 2024(Critical (3))No Ranging Response received - T3 time-out;CM-MAC=6c:cd:d6:ce:65:e4;CMTS-MAC=00:01:5c:77:e6:51;CM-QOS=1.1;CM-VER=3.1;
      Tue Jul 02 15:27:22 2024(Critical (3))SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=6c:cd:d6:ce:65:e4;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Tue Jul 02 15:27:19 2024(Warning (5))Lost MDD Timeout;CM-MAC=6c:cd:d6:ce:65:e4;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Tue Jul 02 15:27:07 2024(Critical (3))SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=6c:cd:d6:ce:65:e4;CMTS-MAC=00:01:5c:77:e6:51;CM-QOS=1.1;CM-VER=3.1;
      Tue Jul 02 15:27:07 2024(Notice (6))DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=6c:cd:d6:ce:65:e4;CMTS-MAC=00:01:5c:77:e6:51;CM-QOS=1.1;CM-VER=3.1;
      Tue Jul 02 15:27:07 2024(Critical (3))SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=6c:cd:d6:ce:65:e4;CMTS-MAC=00:01:5c:77:e6:51;CM-QOS=1.1;CM-VER=3.1;
      Tue Jul 02 15:27:00 2024(Notice (6))TLV-11 - unrecognized OID;CM-MAC=6c:cd:d6:ce:65:e4;CMTS-MAC=00:01:5c:77:e6:51;CM-QOS=1.1;CM-VER=3.1;
      Time Not Established(Warning (5))Lost MDD Timeout;CM-MAC=6c:cd:d6:ce:65:e4;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
