Sallygood25
Sep 09, 2025Follower
CM2050V-speed capped at 50Mb download in a 500Mb plan
I installed this device in my house, put fiber directly on it, it registered without issues. But I noticed a odd issue: Any download is always capped at 50Mb/s (my plan is 500Mb/s for both do...
Sep 10, 2025Guru - Experienced User
The CM series is a modem, not a router.
Which ISP is the modem connected with?
What FW is installed ON the modem?
What brand and model host wifi router is connected to the CM Modem?
What speeds do you see if ethernet connected directly to the back of the CM modem with a ethernet connected PC?
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
Sallygood25 wrote:I installed this device in my house, put fiber directly on it, it registered without issues.
Any download is always capped at 50Mb/s (my plan is 500Mb/s for both downloads and uploads), but UPLOADS happen at full speed (500Mb/s).
I tried some troubleshooting but nothing seems to work!
I suspect it might have to do with firmware (I've updated it to latest firmware), but the problem is I can't find the original firmware that came with it
ISP told me this router is compatilble, and they advised me to contact Netgear, which I'm doing, because it might be a software fault on device's side.
It seems this is a secret device only ISPs have access.
