beachbumsd
Sep 13, 2024Tutor
CM3000 Not achieving high download speeds
I purchased the CM3000 a few weeks ago when my Comcast speeds were increased to 2000 Mbps. After 2 tech visits from Comcast my speeds from the modem do not exceed 800 or so Mbps even though they tes...
Kitsap
Sep 13, 2024Master
What is the name brand and model number of the router you have connected to your CM3000?
If need be, look on the name plate.
beachbumsd
Sep 14, 2024Tutor
I am using Nest Wifi Pro (Wi-Fi 6E) model number G6ZUC.
- KitsapSep 14, 2024Master
beachbumsd wrote:I am using Nest Wifi Pro (Wi-Fi 6E) model number G6ZUC.
Your input/output Ethernet ports are rated at 1 Gbps. In real life you should see a maximum somewhere between 900 to 940 Mbps either via a wired connection or Wi-Fi.
If you stay with that hardware, you are leaving a lot of $ on the table each month paying Comcast for any speed tier above 1 Gbps.
- beachbumsdSep 14, 2024TutorOk I assumed that was the problem all along. Thank you for your response.
Do you recommend a Netgear mesh system that will attain speeds above the 1Gb threshold?- KitsapSep 14, 2024Master
Do you recommend a Netgear mesh system that will attain speeds above the 1Gb threshold?You need to find a router with a 2.5 Gbps input port and connect it to your CM3000 with a Cat 6 Shielded Twisted Pair (STP) Ethernet cable.
There is a good Q/A start point for Netgear Mesh systems here: https://www.netgear.com/home/wifi/mesh/
The start point is a button that says Find Your Orbi Mesh System on the upper left side of the page.
