beachbumsd
Sep 13, 2024Tutor
CM3000 Not achieving high download speeds
I purchased the CM3000 a few weeks ago when my Comcast speeds were increased to 2000 Mbps. After 2 tech visits from Comcast my speeds from the modem do not exceed 800 or so Mbps even though they tes...
beachbumsd
Sep 14, 2024Tutor
Ok I assumed that was the problem all along. Thank you for your response.
Do you recommend a Netgear mesh system that will attain speeds above the 1Gb threshold?
Kitsap
Sep 14, 2024Master
You need to find a router with a 2.5 Gbps input port and connect it to your CM3000 with a Cat 6 Shielded Twisted Pair (STP) Ethernet cable.
There is a good Q/A start point for Netgear Mesh systems here: https://www.netgear.com/home/wifi/mesh/
The start point is a button that says Find Your Orbi Mesh System on the upper left side of the page.
