Ewisnes
Mar 29, 2016Follower
CM400 Blinking Amber Ethernet Light
I am a Time Warner Cable customer and I have been using their rented modem connected to an Apple Airport Express router. I just replaced their rented modem with the CM400. It is connected to the Internet and the ISP says it shows connected on their end. I registered the MAC with them.
My iPad and PS4 are able to use the wi-fi network and connect to the Internet without issue, but two iPhones and a laptop are not. The only negative indication from any hardware is a blinking amber Ethernet light on the CM400. My iPhone just spins when it tries to connect to the wi-fi network. It does not display any technical information, such as IP or DNS. Any idea what the issue could be?
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello Ewisnes
The ethernet blinking amber is normal its just indicates its connected to a 10/100 Mbs device if it was green its connected to a 1000 Mbs device. The issue would be with the airport router you may want to contact apple support for help with the settings on that device.
DarrenM
