KPSAux
Sep 23, 2022Follower
CM400 how to order replacement adapter
The housing on the wire for my CM400 Cable Modem 9V Adapter broke so the Adapter would not connect. I am using an adapter from another company and just found out it has to be from Netgear. How do I ...
Sep 23, 2022Guru - Experienced User
Who told you it had to be from netgear?
Is it causing issues? (the one you're using)
If so, what issues? maybe its not adapter related.
