Ccws16
Jun 14, 2017Aspirant
Cm400 Overheating and slow speed
I've been noticing slow internet speeds over the last month. I'm supposed to have 120mb/s download speed through Comcast but often can barely get more than 10, often around 1 mb/s. Unplugging the modem and router sometimes help jump speeds up to 20 mb/s. I verified the router was not the issue as I plugged the modem directly into a laptop and reset the modem but still only had speed of 0.8 mb/s. I also noticed the modem is really hot to the touch. I used a laser temp gun to measure the heat and it's 110 F on the top and 125 F on the bottom. It's laying on top of a subwoofer out in the open. Firmware V1.01.18
- DarrenMSr. NETGEAR Moderator
Hello CCws16
Are you able to post your power levels and SNR?
DarrenM
- Ccws16Aspirant
Channel Power SNR
1 -0.6 dBmV 36.8 dB
2 -0.3 dBmV 35.9 dB
3 -0.2 dBmV 37.0 dB
4 -0.1 dBmV 37.0 dB
5 -0.3 dBmV 35.9 dB
6 -0.1 dBmV 36.8 dB
7 0.0 dBmV 37.0 dB
8 0.1 dBmV 37.0 dB
Hello Ccws16
If you have checked with comcast about issues on there side and everything is good you may want to contact support if the modem is still under warranty.
http://www.netgear.com/support/contact.aspx
DarrenM
