jannamore's avatar
jannamore
CM500-100NAS Upstream Channels Partial Service
SETUP As the subject references, my modem indicates that it is only locking onto one upstream channel (see logs below). Current setup: Netgear CM500 modem Google WiFi (1 primary, 2 non-prim...
  • vkdelta's avatar
    Jul 22, 2020
    thank for you such a clear description and formatting. I wish other users could be like you!
    your Signal levels are bad.
    for downstream: TONS of Uncorrectables
    for upstream: you got partial service and just ONE UPSTREAM channel that is hanging on last leg. It could die anytime
    I strongly suggest you to call your ISP and ask them to fix the line.
    If you have any splitters or bad cables, remove it
    If you have other outlets in your home, try those if they are better.
    Who is your ISP?
    Is this old home or new build?
