jannamore
Jul 21, 2020Aspirant
CM500-100NAS Upstream Channels Partial Service
SETUP As the subject references, my modem indicates that it is only locking onto one upstream channel (see logs below). Current setup: Netgear CM500 modem Google WiFi (1 primary, 2 non-prim...
- Jul 21, 2020
thank for you such a clear description and formatting. I wish other users could be like you!
your Signal levels are bad.
for downstream: TONS of Uncorrectables
for upstream: you got partial service and just ONE UPSTREAM channel that is hanging on last leg. It could die anytime
I strongly suggest you to call your ISP and ask them to fix the line.
If you have any splitters or bad cables, remove it
If you have other outlets in your home, try those if they are better.
Who is your ISP?
Is this old home or new build?
vkdelta
Jul 21, 2020NETGEAR Employee Retired
Who is your ISP?
jannamore
Jul 23, 2020Aspirant
realized I forgot to answer some of your questions vkdelta - home is old, built in early mid 1900s, wired for cable only, no fiber available; ISP = XFINITY.
- vkdeltaJul 23, 2020NETGEAR Employee Retired
if you see your Channel 6, 10, 11, 12 . there are significantly large amount of uncorrectables, so that means more noise.
also, US power is quite high.
are there disconnections?
are you getting good speeds?
this is not a good signal level (SNR) and US power is too high.
