Bitbanger76251's avatar
Dec 03, 2015
CM500 and CM600 public or private IP address assigned to router?
I would like to use my router's port forwarding capability to remotely access devices on my LAN such as IP cameras. I know that with an integrated modem/router this can be done - I have it working now...
  • vkdelta's avatar
    vkdelta
    Dec 04, 2015
    If you are on Time-warner network, they should assign you a public IP and for e.g. if you connect CM500 Cable modem with a R7000 Router, thr router will get Public IP and you will not have double NAT situation.
    I didnt know which ISP you had service with. some ISPs in asia provide private IPs to the users and it will create double NAT situation.
    I have not seen any ISP so far in US providing Private IPs but I have only worked with Comcasts and Time Warners. Not sure of smaller players.
