RAYANS
Jul 11, 2020Follower
CM500 capped at 100Mbps
I replaced the xfinity cable modem with the CM500-1AZNAS modem. The download speed is stuck at 92Mbps. my earlier xfinitiy cable modem was getting me 200+Mbps.
Called Xfinity and they could not solve this issue on their side. I've seen one more thread on this forum on this same topic but no solution .
Any idea how to resolve this issue.
Standard validations done so far below:
1. test performed with laptop connected via ethernet to the cable modem. ( no router)
2. Powercycled the cable modem
3. xfinity tried resetting the connection from their end.
Thanks in advance.
1 Reply
have you tried replacing the ethernet cable? make sure its cat5e or greater.
What computer is it? It sounds like you're connected at a fast 10/100mbps connection and not gigabit.
any other computers you can try testing with?
are you directly connected to the modem or is there a router connected? if so, what router is connected?
