silver123's avatar
silver123
CM500 intermittent brief connection issues TWC
My cable modem is dropping internet connectivity recently for a few seconds then reconnects.  My neighbors recently installed ATT on each side of my house and I know ATT was inside the box that's in between our houses, I mention this as there's not been any other changes to the system and it never lost connection before they came out to install my neighbors stuff.
My event log is below I saw somewhere where someone said to check the time zone which the router is 1 hour behind the correct time, unsure if that could be the cause but it does not appear that this router gives me any control over changing anything, thanks for your help in advance!
1970-1-1, 00:00:21Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=50:6a:03:7d:92:d0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:27Critical (3)No Ranging Response received - T3 time-out;CM-MAC=50:6a:03:7d:92:d0;CMTS-MAC=00:01:5c:77:c0:5b;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:29Notice (6)Honoring MDD; IP provisioning mode = IPv4
1970-1-1, 00:00:32Warning (5)DHCP WARNING - Non-critical field invalid in response ;CM-MAC=50:6a:03:7d:92:d0;CMTS-MAC=00:01:5c:77:c0:5b;CM-QOS=1.0;CM-VER=3.0;
2016-7-19, 14:14:48Error (4)Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=50:6a:03:7d:92:d0;CMTS-MAC=00:01:5c:77:c0:5b;CM-QOS=1.1;CM-VER=3.0;
2016-7-19, 14:14:48Error (4)Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=50:6a:03:7d:92:d0;CMTS-MAC=00:01:5c:77:c0:5b;CM-QOS=1.1;CM-VER=3.0;
2016-7-19, 14:14:55Critical (3)No Ranging Response received - T3 time-out;CM-MAC=50:6a:03:7d:92:d0;CMTS-MAC=00:01:5c:77:c0:5b;CM-QOS=1.0;CM-VER=3.0;
2016-7-19, 14:14:59Notice (6)Overriding MDD IP initialization parameters; IP provisioning mode = IPv6
2016-7-19, 14:15:11Warning (5)ToD request sent - No Response received;CM-MAC=50:6a:03:7d:92:d0;CMTS-MAC=00:01:5c:77:c0:5b;CM-QOS=1.0;CM-VER=3.0;
2016-7-19, 14:15:12Error (4)Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=50:6a:03:7d:92:d0;CMTS-MAC=00:01:5c:77:c0:5b;CM-QOS=1.1;CM-VER=3.0;
2016-7-19, 14:15:12Error (4)Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=50:6a:03:7d:92:d0;CMTS-MAC=00:01:5c:77:c0:5b;CM-QOS=1.1;CM-VER=3.0;
2016-7-19, 14:16:56Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=50:6a:03:7d:92:d0;CMTS-MAC=00:01:5c:77:c0:5b;CM-QOS=1.1;CM-VER=3.0;
2016-7-19, 14:18:04Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=50:6a:03:7d:92:d0;CMTS-MAC=00:01:5c:77:c0:5b;CM-QOS=1.1;CM-VER=3.0;
2016-7-19, 14:18:13Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=50:6a:03:7d:92:d0;CMTS-MAC=00:01:5c:77:c0:5b;CM-QOS=1.0;CM-VER=3.0;
2016-7-19, 14:18:15Notice (6)Honoring MDD; IP provisioning mode = IPv4
2016-7-19, 14:18:18Warning (5)DHCP WARNING - Non-critical field invalid in response ;CM-MAC=50:6a:03:7d:92:d0;CMTS-MAC=00:01:5c:77:c0:5b;CM-QOS=1.1;CM-VER=3.0;
2016-7-19, 14:18:18Error (4)Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=50:6a:03:7d:92:d0;CMTS-MAC=00:01:5c:77:c0:5b;CM-QOS=1.1;CM-VER=3.0;
2016-7-19, 14:18:18Error (4)Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=50:6a:03:7d:92:d0;CMTS-MAC=00:01:5c:77:c0:5b;CM-QOS=1.1;CM-VER=3.0;
2016-7-19, 14:18:21Critical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=50:6a:03:7d:92:d0;CMTS-MAC=00:01:5c:77:c0:5b;CM-QOS=1.0;CM-VER=3.0;
2016-7-19, 14:18:27Critical (3)No Ranging Response received - T3 time-out;CM-MAC=50:6a:03:7d:92:d0;CMTS-MAC=00:01:5c:77:c0:5b;CM-QOS=1.0;CM-VER=3.0;
2016-7-19, 14:18:29Notice (6)Overriding MDD IP initialization parameters; IP provisioning mode = IPv6
2016-7-19, 14:18:41Warning (5)ToD request sent - No Response received;CM-MAC=50:6a:03:7d:92:d0;CMTS-MAC=00:01:5c:77:c0:5b;CM-QOS=1.0;CM-VER=3.0;
2016-7-19, 14:18:42Error (4)Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=50:6a:03:7d:92:d0;CMTS-MAC=00:01:5c:77:c0:5b;CM-QOS=1.1;CM-VER=3.0;
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello silver123
    I see alot of T3 and T4 timeouts I would say there is a signal issue going on with TWC they may of messed with some cable lines when installing stuff at your neighbors home. I would have TWC send a tech out to check the lines in your place and out at the pole.
    DarrenM
    • silver123's avatar
      silver123
      Thanks, I pretty much figured, which thank GOD when I called them yesterday the tech was inside the US so English wasn't a problem, they're sending out someone Saturday......zero issues today HA so after 4 days of problems the day after I call it resolves itself, but I'm going to have them double check everything anyways.
      I don't get my 300 down as advertised, which I suspect is because I have an OOMA (VOIP) box on the line and that seems to suck up a massive amount of my bandwith
