roll0ver
Apr 11, 2021Aspirant
CM500 Intermittent Packet Loss multiple times daily WOW! Internet
Have called but they keep saying it looks fine from thier end (clearly offshore tech support)
Here is the SYNC timing loss repeadedly in the logs:
| Time | Priority | Description |
| 2021-4-11, 21:11:01 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 21:11:00 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 21:10:58 | Warning (5) | MDD message timeout;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 21:10:54 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 20:41:27 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 20:41:24 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 20:41:23 | Warning (5) | MDD message timeout;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 20:41:20 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 20:11:55 | Warning (5) | MDD message timeout;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 20:11:52 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 20:11:49 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 20:11:48 | Warning (5) | MDD message timeout;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 20:11:45 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 19:42:21 | Warning (5) | MDD message timeout;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 19:42:18 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 19:42:15 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 19:42:14 | Warning (5) | MDD message timeout;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 19:42:11 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 19:12:43 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 19:12:42 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 19:12:41 | Warning (5) | MDD message timeout;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 19:12:37 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 18:43:09 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 18:43:08 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 18:43:06 | Warning (5) | MDD message timeout;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 18:43:02 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 18:13:36 | Warning (5) | MDD message timeout;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 18:13:34 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 18:13:33 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 18:13:32 | Warning (5) | MDD message timeout;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 18:13:28 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 17:44:00 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 17:43:57 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 17:43:56 | Warning (5) | MDD message timeout;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 17:43:53 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 16:44:54 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 16:44:51 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 16:44:50 | Warning (5) | MDD message timeout;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 16:44:47 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
| 2021-4-11, 16:15:23 | Warning (5) | MDD message timeout;CM-MAC=bc:a5:11:96:58:94;CMTS-MAC=00:01:5c:72:78:73;CM-QOS=1.1;CM-VER=3.0; |
1 Reply
- roll0verAspirant
Connection page:
Frequency start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. Starting Frequency Startup Procedure
Procedure Status Comment Acquire Downstream Channel 621000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enabled BPI+ IP Provisioning Mode Honor MDD honorMdd(4) Downstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 14 621000000 Hz -6 dBmV 37.8 dB 2297 6313 2 Locked QAM256 12 603000000 Hz -6.7 dBmV 37.4 dB 681 559 3 Locked QAM256 13 615000000 Hz -6.4 dBmV 37.8 dB 783 829 4 Locked QAM256 16 633000000 Hz -4.5 dBmV 38.4 dB 1650 3825 5 Locked QAM256 17 639000000 Hz -4.1 dBmV 38.7 dB 1585 3935 6 Locked QAM256 18 645000000 Hz -4.5 dBmV 38.9 dB 761 285 7 Locked QAM256 19 651000000 Hz -4.6 dBmV 38.9 dB 726 269 8 Locked QAM256 20 657000000 Hz -4.8 dBmV 38.6 dB 706 361 9 Locked QAM256 21 663000000 Hz -4.8 dBmV 38.6 dB 709 329 10 Locked QAM256 22 669000000 Hz -5.1 dBmV 38.4 dB 746 267 11 Locked QAM256 23 675000000 Hz -5.1 dBmV 37.8 dB 748 272 12 Locked QAM256 24 681000000 Hz -5.6 dBmV 38.3 dB 653 347 13 Locked QAM256 25 687000000 Hz -5.9 dBmV 38.1 dB 724 323 14 Locked QAM256 26 693000000 Hz -6.4 dBmV 37.9 dB 652 399 15 Locked QAM256 27 699000000 Hz -6.3 dBmV 38 dB 647 375 16 Locked QAM256 28 729000000 Hz -5.3 dBmV 37.2 dB 729 3052 Upstream Bonded Channels
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 85 5120 Ksym/sec 21900000 Hz 46.3 dBmV 2 Locked ATDMA 86 5120 Ksym/sec 28300000 Hz 47 dBmV 3 Locked ATDMA 87 5120 Ksym/sec 34700000 Hz 47.3 dBmV 4 Locked ATDMA 88 2560 Ksym/sec 39500000 Hz 47.5 dBmV
