labasedlife
May 18, 2021Aspirant
CM500 Modem drops internet connection , then reconnects eventually
The attachments are from the other day when it dropped last
labasedlife
May 18, 2021Guru - Experienced User
check your line for signal attenuators, splitters, amplifiers.
Remove them if you do.
Also, check the cable for kinks, damage, poor/old/loose/corroded connectors.
You have errors in your line and the logs having connection errors.
