Kel22's avatar
Kel22
Cm500. Network name does not appear on devices
My WiFi does not appear on any of my devices. The WiFi coming into the house works but the name does not appear as a choice. We did reset it from the back. CM 500
  • plemans's avatar
    CM500 is a modem only. It doesn't have a router or wifi built in. Its strictly modem only.
    • Kel22's avatar
      Kel22
      Thank you for replying.  We finally did figure out that our problem was the switch.  Modem wasn't talking to the Router.
      • plemans's avatar
        hopefully you don't have a switch between the router and the modem.
        it should go modem------>router------>switch
