syntax
Sep 08, 2017Aspirant
cm500 or cm600
i want to know if CM500-100NAS just as stable as the cm600 Would this work on charter has anyone had prob with it?
- Sep 08, 2017
CM500 = 16x4 bonding
CM600 =24x8 bonding
both should work on Spectrum/charter.
syntax
What one you would pick and what be good for 60 Mbps 5 upload?Would make my speed go up?
vkdelta
Sep 08, 2017NETGEAR Employee Retired
for that 60/5, CM500 is good enough (unless you plan to upgrade to 200 or 300 Mbps service in future).
If you plan to stay with 60/5 service, just spend less $ on CM500 and no need for CM600 as CM600 is bit more expensive than CM500.
- syntaxSep 08, 2017Aspirant
Would my speed go over 60 Mbps?
- vkdeltaSep 08, 2017NETGEAR Employee Retired
who is the ISP?
In most cases it would be -/+ 5 to 10% of the committed rate (60Mbps) and depending on congestion in your area/node and peak/off-peak hours.
typically COMCAST DOCSIS config files are slightly over provisioned. for 60 Mbps, they might provision it 65 Mbps. Other ISPs, not sure about it.
Charter I get sometime about 67 Mbps on my old modem.
