syntax
Sep 08, 2017Aspirant
cm500 or cm600
i want to know if CM500-100NAS just as stable as the cm600 Would this work on charter has anyone had prob with it?
- Sep 08, 2017
CM500 = 16x4 bonding
CM600 =24x8 bonding
both should work on Spectrum/charter.
vkdelta
Sep 08, 2017NETGEAR Employee Retired
make sure your problem is not due to bad noise on Charter's line.
In that new modem may not really help you.
syntax
Sep 09, 2017Aspirant
More channel would it help when more people are online with cable?
- vkdeltaSep 10, 2017NETGEAR Employee Retired
more people in your home or more people in your area?
- syntaxSep 10, 2017Aspirant
More device and when there more charter Peak hours.
for 60 Mbps package, it would not make a big difference.
If you had 300 Mbps, it would make a difference.
- syntaxSep 12, 2017Aspirant
Could be my one of my upload are not working be the prob.
