PS92262
Sep 23, 2017Follower
CM500 overheating?
I purchased a CM500 cable router through Amazon. The connection was fairly easy and the spees ery fast, but the modem got very hot and stayed that way. I spoke to Amazon first to see if others had ...
marknetnyc
Nov 03, 2017Aspirant
Hi,
I just bought NetGear CM500 modem and when I turn on and leave it on for a short time, it gets warm to the touch on both sides. At first I laid it flat. It got very hot. Then I placed it vertically. It still gets warm. Plus the metal screw where the Cable wire will go gets rather hot.
I've been reading reviews of various other modems and seems they experience the same thing.
My older modem was designed to be placed flat with all open ventilation on top. It never got warm to the touch.
1. Is the vertical design, which seems to contribute to the modem getting hot, safe to use? I don't want any fires!!
2. Is there another type of NetGear modem that is safer to use that won't get warm or hot to the touch?
vkdelta
Nov 03, 2017NETGEAR Employee Retired
#1. If it overheats, it will show up RED on the power LED the device will shutdown by itself.
#2. CM500 is safe. If you do need models with more holes, you can check CM600, CM700 or CM1000. their design is different and it has more holes.
