Chazz
Oct 07, 2015Tutor
CM500 status log for high db power on upstream
1 Locked ATDMA 53 5120 Ksym/sec 34800000 Hz 54 dBmV 2 Locked ATDMA 54 5120 Ksym/sec 27900000 Hz 54 dBmV 3 Locked ATDMA 55 5120 Ksym/sec 21000000 Hz 54 dBmV ...
- Oct 12, 2015
Upstream power is still too hot (ideally should be dropped by 6 dB if possible). I think someone at the ISP side need to reduce one of the attenuators in the upstream direction.
are you facing any dropouts?
Chazz
Oct 08, 2015Tutor
Thanks for reply.
I have one splitter in a bedroom with a power supply feeding it. I call it a wall wart. There may be one more splitter at the box outside.
Would it be worth eliminating the one outside and I believe I don't need it anyway. To get a quicker or smoother connection?
vkdelta
Oct 09, 2015NETGEAR Employee Retired
yeah, better to eliminate spliters you really dont need.
are you mixing Satellite (direcTV, Dish, etc) and Cable connections in your home? I guess now. Most people who have outside splitter, they have Internet from Cable company and TV service from satellite guy. OR sometimes it is just something old owner put that in.
- ChazzOct 09, 2015Tutor
No, comcast for tv and internet. im getting a diagram together so ill know how the wire runs and what splitters are there. I know its a littlke jacked up cause they were in a hurry. The installers didnt know ive been a low voltage tech for 20+ years lmao. Will get back to you on counts.
- vkdeltaOct 09, 2015NETGEAR Employee Retired
Sure. Let me know.
Ok mapped all coax from pole to the modem. Have (1) subscriber amplifier CSAPDU5VP AND (1) powered splitter to one of the bedrooms.
I eliminated both pieces of equipment so main feed goes straight to the modem ranted theres a (2) coax couplings and say 50ft RG6.
Rebooted modem and still getting same db levels.
Acquire Downstream Channel 747000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enabled BPI+ IP Provisioning Mode Honor MDD honorMdd(4) Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 53 5120 Ksym/sec 34800000 Hz 54 dBmV 2 Locked ATDMA 54 5120 Ksym/sec 27900000 Hz 54 dBmV 3 Locked ATDMA 55 5120 Ksym/sec 21000000 Hz 54 dBmV Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 16 747000000 Hz 3.3 dBmV 39.8 dB 0 0 2 Locked QAM256 1 657000000 Hz 6.2 dBmV 40.6 dB 0 0 3 Locked QAM256 2 663000000 Hz 4.5 dBmV 40.2 dB 0 0 4 Locked QAM256 3 669000000 Hz 3.1 dBmV 40 dB 0 0 5 Locked QAM256 4 675000000 Hz 2 dBmV 39.6 dB 0 0 6 Locked QAM256 5 681000000 Hz 1.9 dBmV 39.9 dB 0 0 7 Locked QAM256 6 687000000 Hz 2.4 dBmV 40 dB 0 0 8 Locked QAM256 7 693000000 Hz 3.7 dBmV 40.2 dB 0 0 9 Locked QAM256 8 699000000 Hz 5.6 dBmV 40.3 dB 0 0 10 Locked QAM256 9 705000000 Hz 7.4 dBmV 40.6 dB 0 0 11 Locked QAM256 10 711000000 Hz 7.5 dBmV 40.5 dB 0 0 12 Locked QAM256 11 717000000 Hz 5.6 dBmV 40.2 dB 0 0 13 Locked QAM256 12 723000000 Hz 3.7 dBmV 40 dB 0 0 14 Locked QAM256 13 729000000 Hz 2.5 dBmV 39.8 dB 0 0 15 Locked QAM256 14 735000000 Hz 2.3 dBmV 39.8 dB 0 0 16 Locked QAM256 15 741000000 Hz 2.6 dBmV 39.7 dB
