Chazz
Oct 07, 2015Tutor
CM500 status log for high db power on upstream
1 Locked ATDMA 53 5120 Ksym/sec 34800000 Hz 54 dBmV 2 Locked ATDMA 54 5120 Ksym/sec 27900000 Hz 54 dBmV 3 Locked ATDMA 55 5120 Ksym/sec 21000000 Hz 54 dBmV ...
- Oct 12, 2015
Upstream power is still too hot (ideally should be dropped by 6 dB if possible). I think someone at the ISP side need to reduce one of the attenuators in the upstream direction.
are you facing any dropouts?
vkdelta
Oct 09, 2015NETGEAR Employee Retired
Sure. Let me know.
Chazz
Oct 09, 2015Tutor
Ok mapped all coax from pole to the modem. Have (1) subscriber amplifier CSAPDU5VP AND (1) powered splitter to one of the bedrooms.
I eliminated both pieces of equipment so main feed goes straight to the modem ranted theres a (2) coax couplings and say 50ft RG6.
Rebooted modem and still getting same db levels.
- vkdeltaOct 12, 2015NETGEAR Employee Retired
