Chazz
Oct 07, 2015Tutor
CM500 status log for high db power on upstream
1 Locked ATDMA 53 5120 Ksym/sec 34800000 Hz 54 dBmV 2 Locked ATDMA 54 5120 Ksym/sec 27900000 Hz 54 dBmV 3 Locked ATDMA 55 5120 Ksym/sec 21000000 Hz 54 dBmV ...
- Oct 12, 2015
Upstream power is still too hot (ideally should be dropped by 6 dB if possible). I think someone at the ISP side need to reduce one of the attenuators in the upstream direction.
are you facing any dropouts?
Chazz
Oct 12, 2015Tutor
Thanks so much
