jdebery's avatar
jdebery
CM500
Where do I find the network security key?
  • plemans's avatar
    what network security key are you looking for?
    The cm500 is a modem only device. It doesn't have wifi and has very basic gui in you log in and view.
    There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/
    Type in your model number and from there it'll take you to the above.
    Its a great resource to start with.
      • plemans's avatar
        Your title literally says "cm500"
        Thats the modem's model number
