mediatrek's avatar
mediatrek
Virtuoso
Mar 25, 2016
CM600 & CM400 Product Security Vulnerability
Before buying the Netgear CM600, I was wondering if the CSRF / LocalFile / XSS product vulnerability has been fixed yet? The support entry on the issue mentions the update should be released by the e...
  • DarrenM's avatar
    Mar 29, 2016
    Hello mediatrek
    Yes we have a fix but it will take time to go through certification so I have no ETA on when the firmware will be released with the fix.
    DarrenM
