wappinne
Mar 01, 2019Aspirant
CM600 & MOCA Adapter
How do I wire a CM600 Netgear cable modem to work with Actiontec bonded MOCA adapters?
Is it COAX from wall to adapter; then COAX from adapter to modem, then ethernet from modem to router, and ...
antinode
Mar 01, 2019Guru
"work" to solve what problem? What are you trying to connect to
what? Where is the co-ax cable? What is "wall"?
Presumably, you have some kind of co-ax connection to your ISP, which
should go (somehow) to the co-ax port on the CM600. Other than that, I
have no idea what you want to do.
