wappinne
Mar 01, 2019Aspirant
CM600 & MOCA Adapter
How do I wire a CM600 Netgear cable modem to work with Actiontec bonded MOCA adapters?
Is it COAX from wall to adapter; then COAX from adapter to modem, then ethernet from modem to router, and ...
antinode
Mar 01, 2019Guru
"work" to solve what problem? What are you trying to connect to
what? Where is the co-ax cable? What is "wall"?
Presumably, you have some kind of co-ax connection to your ISP, which
should go (somehow) to the co-ax port on the CM600. Other than that, I
have no idea what you want to do.
wappinne
Mar 02, 2019Aspirant
Sorry; I have xfinity coming in via coax. I have my cm600 modem on one floor. It's connected to an Airport router / wifi access point. I want to use the coax in the house to transmit internet instead of using the wifi. So I am thinking of getting a pair of Actiontec MOCA adapters to do that. I'm just not sure of the wiring. I've seen two configurations: one without a splitter and one with. I'm trying to dicern which to use. Blue lines are coax; red are ethernet.
