KevTech
Jun 23, 2016Tutor
CM600 Chipset
Just wondering if anyone knew what chipset is in the CM600. What I wondered was if it is the same as the Arris SB6190 or different.
mediatrek
Jun 24, 2016Virtuoso
The CM600 is powered by the Broadcom BCM3384 chip, whereas the Arris SB6190 is powered by a chip from the Intel Puma family of products.
The BCM3384 is a dual-thread 600MHz chip.
Please do note that the CM600 has a known security vulnerability (see thread: https://community.netgear.com/t5/Cable-Modems-Routers/CM600-amp-CM400-Product-Security-Vulnerability/m-p/1065962#M2658).
The vulnerability was known since the Fall of 2015, and Netgear said they would have a fix by December 2015. Here it is June 2016 and my ISP (Time Warner Cable / "Spectrum") has told me they have not gotten any firmware from Netgear to even test yet.
KevTech
Jun 24, 2016Tutor
Thanks for the info.
I first connected the CM600 without the coax connected to check firmware the modem came with and it had firmware 1.01.05
As soon as I connected the coax the firmware upgraded to 1.01.09
Perhaps that firmware has the fix?
My ISP is Comcast.
