bodosom
Apr 15, 2016Aspirant
CM600 error counts still zero after three days.
I've had a CM600 on-line for 3 days and the downstream error counts are still zero. Is this a firmware issue or a hardware fault or did my line become amazingly error free for the last few days?
VE6CGX
Jun 11, 2016Master
Are complaining about zero error count? You don't like good line qulity. Errors occuring on data network is common thing. If there is any other issues what is the worry? Don't knock the wood!, LOL...
Jim769
Jun 11, 2016Luminary
Yes your not understanding of course we all like a clean network the point is the CM-600 does not report errors at all even unplugging the coax from the modem for 10 minutes shows 0 errors this is not right. I would rather have a modem that showed me issues then one that hides them from the user and shows nothing. It appears the system log does work as i have had a few T-3 timeouts that is normal arounf here. But as far as correctable/uncorrectable code words go zip notta only a few one time after a major outage.
