Sca555's avatar
Sca555
Cm600 errors
I have Spectrum and my internet has been acting up for a while now and decided to check my logs and I saw these events. I'm not very knowledgeable in this area.
  • plemans's avatar
    your actual signal strength looks fine but your log is showing issues back to the isp.
    If you have any splitters, amplifiers, attenuators in the coax line, remove them. Then try it for a bit.
    If you still have issues, the isp needs to check the line.
    • Sca555's avatar
      Sca555
      Thanks I already have my cable company coming out tomorrow. I realized yesterday that although I only have one line coming into the house there's still 3 2-way splitters outside of my house that my line comes from. Makes no sense.
      • plemans's avatar
        yeah, that could cause issues.
        Usually you put 1x 2-way splitter with one leg feeding the modem and the other feeding the reset of the home (cable boxes). that way the modem gets the best possible speed.
