djc6's avatar
djc6
Luminary
Dec 28, 2016
CM600 ethernet light blinks when nothing plugged in
I recently purchased a Netgear CM600 to replace my Arris SB6190 due to the whole Puma 6 chipset debacle:
https://www.dslreports.com/shownews/Arris-Tells-us-Its-Working-With-Intel-on-SB6190-Puma6-Problems-138434
Anyways, I noticed on my CM600 that the ethernet light blinks green always - even when nothing is plugged into the ethernet port on the modem.  Is this expected/normal?  My modem has firmware V1.01.05
  • Cox updated firmware on my modem to V1.01.06 overnight - I notice that now when ethernet cable is unplugged, the light stops blinking.  It seems to only blink with activity now.
1 Reply
