lancek's avatar
lancek
Initiate
Mar 15, 2016
CM600 Hot Operating Temperature 109 Degrees Fahrenheit - Fire Hazard?
Just purchased a Netgear CM600 and noticed that its normal operating temperature was hot compared to my other electronic devices (Arris SB6183, Netgear WND3400 V2). The Arris and WND3400V2 were cool ...
  • mediatrek's avatar
    Mar 16, 2016
    I could not find info on the CM600’s internal operating temperatures, but it is rated to operate in environments up to 104 degrees ferhenheit.Does the power LED light blink red at all on your unit? If so, that is the indication that the unit is too warm and is overheating.
    The CM600 is powered by the Broadcom BCM3384 chip, and I could not find a datasheet that offered temp ranges for that either.
