lancek
Mar 15, 2016Initiate
CM600 Hot Operating Temperature 109 Degrees Fahrenheit - Fire Hazard?
Just purchased a Netgear CM600 and noticed that its normal operating temperature was hot compared to my other electronic devices (Arris SB6183, Netgear WND3400 V2). The Arris and WND3400V2 were cool ...
- Mar 16, 2016
I could not find info on the CM600’s internal operating temperatures, but it is rated to operate in environments up to 104 degrees ferhenheit.Does the power LED light blink red at all on your unit? If so, that is the indication that the unit is too warm and is overheating.
The CM600 is powered by the Broadcom BCM3384 chip, and I could not find a datasheet that offered temp ranges for that either.
mediatrek
Mar 16, 2016Virtuoso
lancek
Mar 17, 2016Initiate
The power LED is not blinking red.
So that means it is safe for room temperatures at 104 degrees and below. Hopefully that is true.
It also seems that it is only the top 1/4 of the device gets hot. The bottom 3/4 is cool.
Thanks for your input.
- vkdeltaMar 25, 2016NETGEAR Employee Retired
It does not look that hot.
can you find the temp on top housing by touching a vent area and a non-vent area?
