Retired_Member
Jul 29, 2022CM600 modem blinking amber down stream led NO upstream led
I came home tonight to my CM600 modem with a green power led and a blinking amber downstream led. I have looked into the led states, but found no reference for a blinking amber downstream led. My ISP ...
Jul 29, 2022Guru - Experienced User
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
