Sean126
May 13, 2016Aspirant
CM600 on TWC has extremely slow speeds after switching from an Arris brand
I've always been a loyal Netgear router man. Since Time Warner Cable has increased the speeds in my area to 300 megs I had to upgrade my modem from an Arris 6141 to the Netgear cm600 because the Arris would top out around 100 megs. I Since I had such good luck with the routers I thought I'd try netgear modems. Hooked up the modem like I was suppose to, called TWC to activate it....they did. I got on the internet and did the speed test through speedtest.net and was only getting from 2 megs to 20 megs. Tried it 4 or 5 times. Rebooted my computer and tried it a few more times while I had TWC on the phone. Same thing. Slow speeds. The rep asked if I wanted to try the Arris again and when I did the speeds were back up to normal....around 90-100 megs. I've got a service man coming out next week....is there anything I need to make sure he knows when he gets here so i can get this solved in one visit? Or is there anything I try over the phone with TWC before the tech gets here next week?
I tried connecting to 192.168.100.1 when I had the cm600 activated and I couldn't...It wouldn't connect to the IP site, but it would connect to other regular sites.
I'm running on Windows 7 OS.
Any help would be appreciated. Thanks
Thanks.
1 Reply
- Sean126AspirantNever mind. I figured I would try rebooting the modem and then calling TWC and try activating again before the tech came. When I did the two lighting bolts (upload and download stream searchers) kept flashing for over 15 minutes. Its my understanding they are supposed to stay solid at some point, so I rebooted again and again the same thing happened so I took it back and exchanged it and the new one works fine.
