TCsteve's avatar
TCsteve
CM600 Rebooting
Hello,
We have a CM600 modem serving our company buildilng (about 20 active workstations, 1 public web server).  The modem seems to be rebooting several times per day, which brings down all internet and phone service in the building.  I've pasted the logs below, we had reboots shortly after 10:40, shortly before 11:00, and shortly before 11:05.
From the status page:
Hardware Version 1.01B
Firmware Version V1.01.06
Time
Priority
Description
2016-02-12, 11:06:10
Warning (5)
DHCP WARNING - Non-critical field invalid in response ;CM-MAC=dc:ef:09:89:1e:e0;CMTS-MAC=00:12:d9:54:2b:32;CM-QOS=1.1;CM-VER=3.0;
Notice (6)
TLV-11 - unrecognized OID;CM-MAC=dc:ef:09:89:1e:e0;CMTS-MAC=00:12:d9:54:2b:32;CM-QOS=1.1;CM-VER=3.0;
2016-02-12, 11:06:06
Notice (6)
Honoring MDD; IP provisioning mode = IPv4
2016-02-12, 11:05:53
Critical (3)
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=dc:ef:09:89:1e:e0;CMTS-MAC=00:12:d9:54:2b:32;CM-QOS=1.1;CM-VER=3.0;
2016-02-12, 11:05:51
Warning (5)
MDD message timeout;CM-MAC=dc:ef:09:89:1e:e0;CMTS-MAC=00:12:d9:54:2b:32;CM-QOS=1.1;CM-VER=3.0;
2016-02-12, 11:05:48
Warning (5)
Critical (3)
SYNC Timing Synchronization failure - Failed to receive MAC SYNC frame within time-out period;CM-MAC=dc:ef:09:89:1e:e0;CMTS-MAC=00:12:d9:54:2b:32;CM-QOS=1.1;CM-VER=3.0;
2016-02-12, 11:05:36
Critical (3)
2016-02-12, 11:05:35
Critical (3)
SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=dc:ef:09:89:1e:e0;CMTS-MAC=00:12:d9:54:2b:32;CM-QOS=1.1;CM-VER=3.0;
2016-02-12, 11:05:21
Critical (3)
Critical (3)
2016-02-12, 11:05:05
Critical (3)
Critical (3)
2016-02-12, 11:04:32
Critical (3)
2016-02-12, 11:03:53
Warning (5)
2016-02-12, 11:03:52
Critical (3)
2016-02-12, 11:03:13
Critical (3)
2016-02-12, 11:02:30
Notice (6)
2016-02-12, 11:02:28
Warning (5)
2016-02-12, 11:02:25
Notice (6)
2016-02-12, 11:02:16
Critical (3)
SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=dc:ef:09:89:1e:e0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
Critical (3)
SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=dc:ef:09:89:1e:e0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
2016-02-12, 11:02:15
Critical (3)
2016-02-12, 11:01:37
Critical (3)
No UCDs Received - Timeout;;CM-MAC=dc:ef:09:89:1e:e0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
2016-02-12, 11:01:27
Warning (5)
Lost MDD Timeout;CM-MAC=dc:ef:09:89:1e:e0;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
2016-02-12, 11:01:20
Critical (3)
2016-02-12, 11:01:19
Critical (3)
2016-02-12, 11:01:18
Critical (3)
2016-02-12, 11:01:16
Critical (3)
2016-02-12, 11:01:02
Critical (3)
Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=dc:ef:09:89:1e:e0;CMTS-MAC=00:12:d9:54:2b:32;CM-QOS=1.1;CM-VER=3.0;
2016-02-12, 11:00:53
Warning (5)
Notice (6)
2016-02-12, 11:00:49
Notice (6)
2016-02-12, 11:00:38
Critical (3)
2016-02-12, 11:00:32
Critical (3)
2016-02-12, 11:00:20
Critical (3)
Critical (3)
2016-02-12, 11:00:05
Critical (3)
Critical (3)
2016-02-12, 10:59:51
Critical (3)
Critical (3)
2016-02-12, 10:58:47
Warning (5)
2016-02-12, 10:58:46
Critical (3)
2016-02-12, 10:58:39
Critical (3)
Warning (5)
2016-02-12, 10:57:33
Warning (5)
2016-02-12, 10:46:27
Critical (3)
SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=dc:ef:09:89:1e:e0;CMTS-MAC=00:12:d9:54:2b:32;CM-QOS=1.1;CM-VER=3.0;
Critical (3)
2016-02-12, 10:46:25
Warning (5)
2016-02-12, 10:46:24
Critical (3)
2016-02-12, 10:46:01
Warning (5)
2016-02-12, 10:45:43
Notice (6)
2016-02-12, 10:45:42
Warning (5)
2016-02-12, 10:45:39
Notice (6)
2016-02-12, 10:45:30
Critical (3)
2016-02-12, 10:45:22
Critical (3)
2016-02-12, 10:45:21
Critical (3)
2016-02-12, 10:45:18
Critical (3)
2016-02-12, 10:45:17
Critical (3)
2016-02-12, 10:44:15
Critical (3)
2016-02-12, 10:44:14
Critical (3)
Critical (3)
2016-02-12, 10:44:00
Critical (3)
Critical (3)
2016-02-12, 10:43:44
Critical (3)
2016-02-12, 10:43:43
Critical (3)
2016-02-12, 10:43:29
Critical (3)
Critical (3)
2016-02-12, 10:42:21
Warning (5)
2016-02-12, 10:42:20
Critical (3)
2016-02-12, 09:41:16
Critical (3)
2016-02-12, 09:27:10
Critical (3)
No Ranging Response received - T3 time-out;CM-MAC=dc:ef:09:89:1e:e0;CMTS-MAC=00:12:d9:54:2b:32;CM-QOS=1.1;CM-VER=3.0;
2016-02-12, 09:26:39
Critical (3)
2016-02-12, 09:26:09
Warning (5)
  • More information:
    Startup Procedure
    ProcedureStatusComment
    Acquire Downstream Channel819000000 HzLocked
    Connectivity StateOKOperational
    Boot StateOKOperational
    SecurityEnableBPI+
    IP Provisioning ModeHonor MDDIPv4 only
    Downstream Bonded Channels
    ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectables
    1LockedQAM256122819000000 Hz2.4 dBmV39.8 dB1093052209014
    2LockedQAM256121813000000 Hz2.5 dBmV39.9 dB68134
    3LockedQAM256123825000000 Hz2.5 dBmV39.8 dB727811815446
    4LockedQAM256124831000000 Hz2.2 dBmV39.7 dB96163
    5LockedQAM256125837000000 Hz2.1 dBmV39.7 dB1009532444922
    6LockedQAM256126843000000 Hz1.8 dBmV39.5 dB602790925511
    7LockedQAM256127849000000 Hz1.8 dBmV39.6 dB3445691251083
    8LockedQAM256128855000000 Hz1.7 dBmV39.5 dB1037790134517
    9LockedQAM256129861000000 Hz1.7 dBmV39.4 dB86123470816
    10LockedQAM256130867000000 Hz1.6 dBmV39.4 dB84600261955
    11LockedQAM256131873000000 Hz1.4 dBmV39.3 dB79669759534
    12LockedQAM256132879000000 Hz1.1 dBmV39.2 dB1552561719
    13LockedQAM256133885000000 Hz0.7 dBmV38.9 dB1062145302523
    14LockedQAM256134891000000 Hz0.2 dBmV38.5 dB1319619256
    15LockedQAM256135897000000 Hz-0.1 dBmV38.5 dB789919041
    16LockedQAM256136903000000 Hz-0.5 dBmV38.1 dB1314838882
    17LockedQAM256137909000000 Hz-0.4 dBmV38.2 dB00
    18LockedQAM256138915000000 Hz-0.7 dBmV38.0 dB00
    19LockedQAM256139921000000 Hz-0.9 dBmV37.8 dB00
    20LockedQAM256140927000000 Hz-1.1 dBmV37.7 dB00
    21LockedQAM256141933000000 Hz-1.2 dBmV37.5 dB00
    22LockedQAM256142939000000 Hz-1.4 dBmV37.2 dB00
    23LockedQAM256143945000000 Hz-1.2 dBmV37.1 dB00
    24LockedQAM256144951000000 Hz-1.2 dBmV37.1 dB00
    Upstream Bonded Channels
    ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
    1LockedATDMA25120 Ksym/sec23300000 Hz41.5 dBmV
    2LockedTDMA and ATDMA12560 Ksym/sec18400000 Hz42.0 dBmV
    3LockedATDMA35120 Ksym/sec29800000 Hz44.0 dBmV
    4LockedATDMA45120 Ksym/sec36300000 Hz45.5 dBmV
    • DarrenM's avatar
      DarrenM
      Sr. NETGEAR Moderator
      Hello TCsteve
      Have you had a tech out from the cable company to check the signal strength I am seeing timeouts it could be a bad cable splitter on the line some where.
      DarrenM
