jrhockin
Jul 01, 2018Aspirant
CM600 upload light turns amber
Model CM600
Just did a factory reset. Maybe that will solve the prolem that the UPLOAD LIGHT turns amber after a while. Also, before I did the reset, the modem would just not work and lights flash. Maybe this will solve the problem after the reset? But it had just quit working about every other day. Anybody experience this?
- vkdeltaNETGEAR Employee Retired
you signal coming in has issues. Please post your power table and DOCSIS event logs from the GUI.
Amber on US means it is not bonded.
- jrhockinAspirant
Cable Connection
Help Center
Show/Hide Help Center- vkdeltaNETGEAR Employee Retired
thanks. if you see your US power, it is too high (it is supposed to be bonded 3 or 4 US channels, but you have only 1).
Either you need to remove splitters in your house or ask ISP to decrease attenuation to give you extra few dBs margin.
